Tsailor
#1 Posted : Friday, March 4, 2011 3:51:27 PM(UTC)
Tsailor
I have a Whirlpool Duet Dryer. My wife was using it the other morning when it just up and stopped running. I have taken it apart and checked all connections, nothing lose. I have run a diagnostic and I'm showing no error codes. The control panel appears to be working properly. However when you press the start button you hear a click the sensor light lights up and the dryer does not start its cycle. I am at my whits end? Please help!
#2 Posted : Saturday, March 5, 2011 1:38:00 AM(UTC)
Replacement parts for WHIRLPOOL GEW9250PW0 ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the tech sheet which you probably already have as you said that you had run the diagnostics but I just want to be sure that you have this info.
I would check the thermal fuse and the belt switch.
File Attachment(s):
GEW9250.pdf (357kb) downloaded 30 time(s).
Tsailor
#3 Posted : Saturday, March 5, 2011 7:28:33 AM(UTC)
Tsailor
Originally Posted by: denman Go to Quoted Post
(Tsailor) Thank you so very much for your response. I sure will try both those suggestions.
Thank You.
johnbet
#4 Posted : Thursday, March 10, 2011 5:16:26 PM(UTC)
johnbet
I am having the same problem. what did you do?
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Cabrio dryer problems (Dryer Repair)
Belarus artsalena 1/19/2017 2:37:30 PM(UTC)
GE dryer problems (Dryer Repair)
by js072384 5/12/2012 9:15:49 PM(UTC)
Dryer Problems (Dryer Repair)
by smartin349 1/1/2012 6:35:54 AM(UTC)
by Mickey_951 10/1/2011 5:53:04 PM(UTC)
Dryer problems (Dryer Repair)
by Shoopes 11/16/2009 5:24:35 PM(UTC)
by talbot 11/2/2009 9:37:55 AM(UTC)
Asko condenser dryer problems (Dryer Repair)
by Marv Sumner 10/19/2009 11:05:38 AM(UTC)
Dryer problems mikeo (Dryer Repair)
by mikeo1899 8/4/2009 9:15:16 AM(UTC)
by berniefl 7/24/2009 6:13:21 AM(UTC)
Dryer problems HELP (Dryer Repair)
by MizzJessica 7/6/2009 10:39:42 PM(UTC)
by mbgrdido 3/24/2009 7:52:23 PM(UTC)
by janezucker 12/29/2008 9:36:33 AM(UTC)
Roper Dryer problems (Dryer Repair)
by b0001744 8/29/2008 9:38:02 AM(UTC)
by Myles.Smith 8/28/2008 6:06:48 PM(UTC)
