20 Pages«<1415161718>»
#151 Posted : Friday, January 7, 2011 7:33:05 PM(UTC)
Originally Posted by: HopHead27 Go to Quoted Post
i have a fridgidare gas drier which I just hooked up (Given to me by a relative who moved and had no room) seems to run ok ignitor turns bright orange for about 10 seconds and then goes out and in a minute or less it tries to light again. I've cleaned everything inside the cabinet replaced coils which arived today from AppliancePartsPros. Tested the old coils and the readings weren't what they should be but were +- 150 ohms didn't check the new ones yet but I suppose its likely something else. what should I check next?
Sorry for the delay.
Make sure there is gas to the dryer and the gas shut off valve on the back of the dryer is open.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE GLGR341AS4 Frigidaire/gas Dryer | AppliancePartsPros.com
HopHead27
#152 Posted : Saturday, January 8, 2011 8:05:08 AM(UTC)
HopHead27
Thank you,sir, for the reply.
I'm pretty sure it is not the gas supply. As I was hooking the gas to the dryer,before tightening the final connection I turned the gas valve on untill I was sure the air was purged from the line. I also had the doors and windows open to make sure the gas got out of the house quickly! I've also checked part #F79 (Sensor) in the burner section of the afore mentioned diagrams it shows 0 Ohms resistance. I'm not sure if the thermostat-heat controll part # f15 in the motor diagram could be the cause. If you think it might be, could you advise me on how to test it it has 3 red wires and one black one.
Thanks for your help it is definately apperciated
#153 Posted : Saturday, January 8, 2011 9:46:04 AM(UTC)
If the igniter goes on and off and the coils are new but there is no gas flow, then the problem more likely is a bad gas valve itself. The part is very expensive.
- The gas valve assembly Part number: AP2138010
vfdfs2
#154 Posted : Sunday, January 9, 2011 2:55:03 PM(UTC)
vfdfs2
I replaced the bad ignitor with a new ignitor and the dryer is now working. Should i even replace the thermal fuse? Assume the thermal fuse is also broken, will the dryer still work properly?
Weldon
Most likely the problem is a bad thermal fuse (#49 on the diagram).
- The thermal fuse Part number: AP3132867
#155 Posted : Monday, January 10, 2011 11:44:10 AM(UTC)
Weldon
Weldon,
That's what you wrote in the first post:
Quote:
...Heard the gas/ignitor come on and vent duct was hot to make sure its really working correctly...
My advices were based on the information you provided and, assuming the igniter did come on, I did not mention this part.
At this point I do not think there is anything wrong with the thermal fuse.
I'm glad you were able to fix it.
vfdfs2
#156 Posted : Monday, January 10, 2011 1:48:37 PM(UTC)
vfdfs2
Thanks Gene.
You basically pointed me in the right direction when i first asked the question, was the ignitor lite? The ignitor was not lite, in fact, when i removed it, the ceramic broke into pieces. Replaced it and dryer is now all good.
Again, thank you. Have a wonderful day.
Weldon
Weldon,
minnehaha
#157 Posted : Monday, January 24, 2011 11:24:31 AM(UTC)
minnehaha
I have a Kenmore 70 Series gas dryer that no longer heats. The dryer tumbles fine, so I am getting ready to troubleshoot it. The model number is: 97576200. Are there any suggestions as where to start besides following the steps at the beginning of this thread? Is there a diagram/manual that I can download to help me troubleshoot? Thanks.
#158 Posted : Monday, January 24, 2011 12:01:10 PM(UTC)
Originally Posted by: minnehaha Go to Quoted Post
...Are there any suggestions as where to start besides following the steps at the beginning of this thread?...
Your dryer is a classic gas dryer. So you can use the same instructions.
minnehaha
#159 Posted : Tuesday, January 25, 2011 3:17:20 AM(UTC)
minnehaha
Thank you Gene. A strange thing happened with the dryer. While I was at work, my wife did laundry. She thought I had fixed it since I spent a lot of time in the basement lately (working on her surprise birthday gift). So nothing was done to the dryer and it went from no heat to working just fine.
kristathet
#160 Posted : Sunday, February 13, 2011 9:29:12 AM(UTC)
kristathet
hello Gene,
My gas dryer tumbles with air but it doesn't get hot and the timer only rotates on timed dry and perm press.
I have a Frigidaire fsg747ge model gas dryer and cannot find all the parts you've quoted in your 5 parts list.
Can you help me distinguish these major parts for my appliance?
Or do I need to take a different route to repair my issue?
Guest (11)
