Hopefloats40
#1 Posted : Tuesday, October 19, 2010 10:10:49 AM(UTC)
Hopefloats40
I have a Tappan gas stove/oven. Not sure of exact age. It was in the house when we bought it. Was working fine. About a month ago, when using the oven, it took a long time for the oven to light. About 5 minutes or so. Also takes a long time to come to temperature. When temp is reached, does not hold. As soon as flame goes out, again, it takes too long to come back on. We replaced the thermostat because we thought that was the issue. We were incorrect.:(
badbackguy
#2 Posted : Tuesday, October 19, 2010 11:05:21 AM(UTC)
badbackguy
[FONT='Verdana','sans-serif']The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.[/FONT]
Tappan oven or broiler won't ignite (Oven Repair (including Ranges and Cooktops))
by Guest 11/24/2023 6:57:29 AM(UTC)
Tappan oven is heating higher than set point (Oven Repair (including Ranges and Cooktops))
by Burntfood 7/26/2013 6:45:03 PM(UTC)
Tappan oven won't lite-burners all work fine (Oven Repair (including Ranges and Cooktops))
by Dekimpej 4/6/2012 12:33:22 PM(UTC)
Tappan oven/stove not heating up (Oven Repair (including Ranges and Cooktops))
by billyb133 11/24/2011 3:21:53 PM(UTC)
Tappan Oven Broil Element Problem (Oven Repair (including Ranges and Cooktops))
by mike1937 11/20/2011 1:19:28 PM(UTC)
tappan oven/broiler not working (Oven Repair (including Ranges and Cooktops))
by snowdooer 3/7/2011 4:25:44 PM(UTC)
Tappan Oven and broiler inop (Oven Repair (including Ranges and Cooktops))
by RDSDoug 1/15/2011 9:41:18 AM(UTC)
Tappan oven igniter installation (Oven Repair (including Ranges and Cooktops))
by Just George 11/24/2010 9:44:06 AM(UTC)
tappan oven (smell gas but won't heat up) (Oven Repair (including Ranges and Cooktops))
by helgalai 8/3/2010 10:57:58 AM(UTC)
Older Tappan oven won't light (Oven Repair (including Ranges and Cooktops))
by cheale 7/19/2010 6:04:09 PM(UTC)
by rddd1313 10/13/2009 7:04:38 PM(UTC)
Older tappan oven over heats (Oven Repair (including Ranges and Cooktops))
by jbarkley123 7/3/2009 9:41:54 AM(UTC)
Old Tappan Oven overheats (Dishwasher Repair)
by jbarkley123 7/1/2009 4:11:56 AM(UTC)
Tappan Oven not heating (Oven Repair (including Ranges and Cooktops))
by evsolo 4/22/2009 11:48:49 AM(UTC)
Tappan Oven Microwave Combo (Oven Repair (including Ranges and Cooktops))
by mjwhite 4/21/2009 11:40:06 AM(UTC)
