Emily Dunn
#1 Posted : Wednesday, July 16, 2008 4:57:14 PM(UTC)
Emily Dunn
The lower heating element (the igniter?) lights up brightly - as brightly as the broiling element which works fine - but there doesn't seem to be any gas coming out, even after several minutes. The broiler and all burners work well. Could something be clogged? Thanks for any guidance!
#2 Posted : Wednesday, July 16, 2008 8:09:44 PM(UTC)
Hi Emily,
Most common problem in such situation is a bad igniter even if it glows. To test it instrumentally you have to have a special meter which allows to measure the current drawn by the igniter. Normally it suppose to be more than 3.2 amp for a flat igniter.
The model number you posted is incorrect and I'm not able to provide more accurate advise.
Emily Dunn
#3 Posted : Thursday, July 17, 2008 5:01:47 PM(UTC)
Emily Dunn
Many thanks for your reply, Gene. I realized I had accidentally posted the microwave oven model number because we are also having trouble with it. When it rains, it pours. The oven model number is JGB920WEC1WW. I will investigate how to measure the current at the igniter, as I have an electrician friend. Any other advice you might have - I'll follow it!
Emily
#4 Posted : Thursday, July 17, 2008 6:13:49 PM(UTC)
Hi Emily,
Now I've been able to found that the igniter in your oven is a round style, not a flat. The current drawn by a round igniter suppose to be more then 2.5 amps.
- The part number for the igniter is AP2014008
Here are the break down diagrams for the GE range Model JGB920WEC1WW
Double Oven Won't Heat Back Up After Opening (Oven Repair (including Ranges and Cooktops))
by lamoureux.adam@hotmail.com 12/13/2020 11:44:10 AM(UTC)
Lower GE wall oven won't heat up (Oven Repair (including Ranges and Cooktops))
by scalpeldoc 2/6/2019 11:56:18 AM(UTC)
oven won't heat, replaced element seems to have caused more problems (Oven Repair (including Ranges and Cooktops))
by kepu 1/8/2019 10:48:17 AM(UTC)
KitchenAid Electric Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by frosini 10/1/2018 7:23:00 AM(UTC)
Gas Oven won't heat but broiler and burners work fine (Oven Repair (including Ranges and Cooktops))
by Melissabrooks 3/4/2018 6:42:44 AM(UTC)
Oven won't heat (Oven Repair (including Ranges and Cooktops))
by mbreihan59 2/5/2018 5:48:30 PM(UTC)
Lower Oven won't heat (Oven Repair (including Ranges and Cooktops))
by akai230 11/7/2016 5:26:07 PM(UTC)
Maytag Gemini oven won't heat (Oven Repair (including Ranges and Cooktops))
by jmatters 11/24/2015 7:23:04 AM(UTC)
GE Profile Convection Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by igotboost 8/7/2015 10:38:00 AM(UTC)
Ikea Nutid Wall Oven won't heat (Oven Repair (including Ranges and Cooktops))
by Triciav48 6/29/2015 6:36:33 AM(UTC)
Frigidaire oven won't heat (Oven Repair (including Ranges and Cooktops))
by scottrandel 6/28/2015 4:52:44 PM(UTC)
Lower Oven Won't Heat... (Oven Repair (including Ranges and Cooktops))
by FrustratedGeminiOven 3/15/2015 10:45:08 AM(UTC)
by trisha57 4/28/2014 10:23:33 AM(UTC)
Top oven won't heat after self cleaning was done (Oven Repair (including Ranges and Cooktops))
by Dede B 4/6/2014 2:22:53 PM(UTC)
by JLH69 4/5/2014 1:10:19 PM(UTC)
