I recently ordered part #4391960 which is the Heating element. I need to know if I also need to order the dryer thermal fuse. Dryer does everything besides heat.
Originally Posted by: MBKENMORE ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I recently ordered part #4391960 which is the Heating element. I need to know if I also need to order the dryer thermal fuse. Dryer does everything besides heat. MB, Did you have any heat problems before this occurred ? If you had no heating problems, and you find that the element is broken and not shorted out, you will most likely not need a thermal fuse. If you have a test meter or light you can check the fuse for a closed(infinite) circuit. Good Luck, :) :) :)
