cheo
#1 Posted : Thursday, September 6, 2007 6:39:47 PM(UTC)
cheo
;) My Dryer turns on but won't heat. Can you please Help?;)
richappy
#2 Posted : Tuesday, September 11, 2007 2:19:54 AM(UTC)
richappy
If no meter, you are lost, and we can't even try to give advice.
cheo
#3 Posted : Tuesday, September 11, 2007 7:06:40 PM(UTC)
cheo
I am sorry But I dont know what you mean when you said no meter. This is my firts time using the program and I dont understand some terms.
cheo
#4 Posted : Tuesday, September 11, 2007 7:07:46 PM(UTC)
cheo
:confused:
#5 Posted : Tuesday, September 11, 2007 7:30:57 PM(UTC)
Hi cheo
In order to perform a simple troubleshooting you need a regular meter which can help you to check a continuity.
cheo
#6 Posted : Tuesday, September 11, 2007 7:49:54 PM(UTC)
cheo
Hi Gene
Thankyou for your help now I understand what A meter is, And yes I have one. I am Ready for your directions on how troubleshooting my dryer.
#7 Posted : Tuesday, September 11, 2007 8:19:16 PM(UTC)
Pull the dryer out of the wall, unplug the power cord, remove the vent hose from the dryer and remove the back panel.
According to the bulkhead parts break down diagram start the troubleshooting from the thermal fuse (#7). Remove at least one wire from the thermal fuse and check the continuity across terminals.
If the thermal fuse is open it has to be replaced together with the cycling thermostat (#8).
If this is not an issue, go to the thermal cut off (#9) and perform the same continuity test. Replace it if open.
If it's fine then test the heat element (#17). Do not forget to remove at least one wire from the heat element before testing the continuity. Replace it if open.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- The part number for the thermal cut off AP3094244
- The part number for the heating element AP3094254
- Here are the break down diagrams for the Whirlpool electric dryer Model TEDS780JQ0
Good luck.
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
