mailmandennis
#1 Posted : Friday, July 23, 2010 8:11:46 AM(UTC)
mailmandennis
My Maytag Neptune is leaking water out of the door. The door appears to be locked but a great deal of water pours out of the door. The only way to stop it is to put the washer in spin. What could cause this and approximate cost to repair?
Joe / APP Team
#2 Posted : Friday, July 23, 2010 8:26:14 AM(UTC)
Joe / APP Team
It would help very much if we at least had a model number.
You most likely have a clog or hole in the airdome hose or a malfunctioning water level switch, or loose wire connection at either component.
We can help you more effectively with a model number from the serial plate located on the inside panel when the door is opened.
Maytag washer leaking (Washer Repair)
by kpks26 2/5/2014 1:16:48 PM(UTC)
Maytag Washer Leaking (Washer Repair)
by scottlassy 12/11/2012 7:46:32 PM(UTC)
by kaclark7 2/20/2012 5:03:39 PM(UTC)
Maytag Washer Leaking Water into Tub (Washer Repair)
by mightypasta 11/21/2011 8:55:22 AM(UTC)
maytag washer leaking and overflowing (Washer Repair)
by bennettelliott 9/4/2010 11:02:54 AM(UTC)
Maytag washer leaking from bottom (Washer Repair)
by Famof5 7/8/2010 5:29:47 PM(UTC)
Maytag washer leaking, Seems to come from Pump (Washer Repair)
by mikou 11/11/2009 11:04:33 AM(UTC)
Maytag washer leaking only on delicate cycle (Washer Repair)
by bsly58 6/6/2009 5:58:01 PM(UTC)
