Pastor Ken
#1 Posted : Thursday, July 15, 2010 12:47:06 PM(UTC)
Pastor Ken
When the oven is set, after a few minutes the preheat signal sounds but the oven element has never come on. And the oven is not hot. This began after a lighting storm where I had other problems so after checking a few things I replaced the control panel. Same thing. What next? I couldn't find a thermostat on the cutaway and the element (new this spring) appears to be fine.
#2 Posted : Thursday, July 15, 2010 3:58:27 PM(UTC)
Originally Posted by: Pastor Ken Go to Quoted Post
...1/ I replaced the control panel...
...2/ the element (new this spring) appears to be fine...
1/ I'm assuming you replaced the control board (aka a clock)?
2/ Have you checked the heating element for continuity?
Does the Broil work?
Pastor Ken
#3 Posted : Monday, July 19, 2010 9:13:34 AM(UTC)
Pastor Ken
Got it! The element was severed behind the wall in the insulation. We're back in business. Thanks.
KN
Joe / APP Team
#4 Posted : Monday, July 19, 2010 12:47:33 PM(UTC)
Joe / APP Team
Like you, I could not find a thermal fuse or hi limit switch on or in your range diagram. Most free standing ranges do not have them.
I take for granted when you "checked a few things" you also checked for burnt or damaged wires to the element ? and that both breakers set and supplying power to your range.
When you select broil on your control panel, does the upper element come on and heat? with a new control board and if the broil element does come on and heat, this would be a good indication of a damaged wire between your control board and bake element.
If neither element comes on and heats, it would be an indication of a power loss on one of your 120 volt lines to your range(outlet ,breaker,wiring or power cord) and may require an electrician to diagnose and repair as needed.
#5 Posted : Monday, July 19, 2010 12:54:59 PM(UTC)
You are welcome Pastor Ken. We are glad you were able to fix it.
Guest (6)
Whirlpool will not drain or cycle. No Obstructions. What next?? (Dishwasher Repair)
by RyGuy73 3/2/2020 6:29:56 PM(UTC)
Fridge won't start, what next??? (Refrigerator & Freezer Repair)
by gefricot 7/26/2016 10:39:13 AM(UTC)
Dryer still won't heat,what next? (Dryer Repair)
by BSTrue 12/16/2014 3:26:17 AM(UTC)
Dryer--No heat, continuity tests ok...what next? (Dryer Repair)
by davesharpe 1/5/2014 12:48:28 PM(UTC)
Bosch dryer won't heat - tested usual suspects, what next? (Dryer Repair)
by sinoed 9/8/2013 7:00:44 PM(UTC)
Ice covering evaporator coils . . . What next? (Refrigerator & Freezer Repair)
by Dale.1 7/9/2013 8:44:46 PM(UTC)
frigidaire wont drain, pump replaced - what next? (Dishwasher Repair)
by mh1078 4/1/2011 10:25:26 AM(UTC)
Maytag LAT5005AAE has new Lid Switch assembly but fuse continues to blow, what next? (Washer Repair)
by hankshiggs 2/1/2011 11:35:15 AM(UTC)
Replaced defrost thermostat, what next? (Refrigerator & Freezer Repair)
by jesus freak 7/16/2010 7:53:25 PM(UTC)
Maytag washer drain unclogged, what next? (Washer Repair)
by L. Caldwell 6/10/2010 9:12:22 PM(UTC)
What next? (Washer Repair)
by AmanaLWM353W 6/8/2010 11:26:52 AM(UTC)
Overload, Relay, Capacitor Replaced What Next? (Refrigerator & Freezer Repair)
by lrich002 11/16/2009 2:56:48 PM(UTC)
What next??? (Dryer Repair)
by greeneyes49 7/6/2009 10:20:36 AM(UTC)
Replaced defrost heater...coils frosting over again..what next? (Refrigerator & Freezer Repair)
by Momto8 6/15/2009 12:59:11 PM(UTC)
GE Profile New Control Board...What Next?? (Refrigerator & Freezer Repair)
by gratefuldiver 4/21/2009 4:21:15 AM(UTC)
