207 Pages«<7980818283>»
#801 Posted : Friday, April 16, 2010 8:22:57 PM(UTC)
You are welcome and thank you for your good words. Keep us posted.
ratterme
#802 Posted : Saturday, April 17, 2010 6:03:29 AM(UTC)
ratterme
Hi,
Dont mean to hijack a thread but I am new and I didnt want to start a new topic about the same thing.
I have a GE GDS18LBR.. The evap coils keep freezing and stopping the evap fan. I verified with a meter that the heater and thermistat are ok.. so I replaced the defrost timer. However it is still icing over and stopping the fan.
When I manually turn the timer it goes into defrost and the heater heats up and melts the ice.
One thing is The evap motor seems to be making a little more noise than I remember.
Any ideas?
Thank you
Mike
#803 Posted : Saturday, April 17, 2010 3:45:06 PM(UTC)
Mike,
Make sure the drain in the freezer (under the evaporator) is completely open.
Here are the breakdown diagrams and Replacement parts for General Electric GDS18LBRABB Refrigerator | AppliancePartsPros.com
jeffrey_benjamin
#804 Posted : Saturday, April 17, 2010 4:53:13 PM(UTC)
jeffrey_benjamin
Mike,
Hi also ck condition of part # 8 on diagram to make sure it is not water soaked.
ratterme
#805 Posted : Sunday, April 18, 2010 5:24:45 AM(UTC)
ratterme
Hi,
I first want to say thanks everyone for their quick reply.
I have checked the evaporator drain( poured water down and it came out the bottom of the back of the fridge). I also checked Part# 8 and it seems pretty dry. as of right now I have part #2 completely off and I am running the fridge with part# 15 closed up pretty good. Like I said it seems the defrost cycle is doing its job however the evap coils seem to ice over pretty fast(~1hour maybe less) and stop the evap fan.
Not sure but I would say this either is poor circulation from the evap fan, or lack of refrigerant but I dont think thats possible. ?
Thanks again!
Mike
#806 Posted : Monday, April 19, 2010 6:40:13 PM(UTC)
Quote:
...the evap coils seem to ice over pretty fast(~1hour maybe less)...
I hour since the end of the defrost cycle?
ratterme
#807 Posted : Monday, April 19, 2010 6:52:10 PM(UTC)
ratterme
Yes, and as soon as I plug it in.
Mike
jeffrey_benjamin
#808 Posted : Monday, April 19, 2010 7:01:02 PM(UTC)
jeffrey_benjamin
Check your evaporator fan motor rotation & can you identify where the fan is touching the ice? Is it in the housing or the evaporato coil ice . After 1 hour it should not build up so much ice to block the fan. Put the cover back on & ck air flow in both freezer & ref section. Also is the evaporator fully frosted going down to the SUCTION LINE . :rolleyes:
labjr
#809 Posted : Thursday, April 22, 2010 6:11:37 AM(UTC)
labjr
Hello everyone. This is my first post.
I have a model GSH22JFTACC which is freezing up. The main board was changed in January but is still freezing up. After reading a bit. I looked for the thermistors. I think they are original since they don't appear to be spliced. I'll try to test them next.
Does anyone know if there's away to get the computer to turn on the defrost cycle besides jumping out the line and defrost terminals?
#810 Posted : Thursday, April 22, 2010 12:35:14 PM(UTC)
I do not think this model has ability to force defrost cycle.
