2 Pages12>
bobirino
#1 Posted : 15 years ago
bobirino
I cannot get a burner to light.
I have switched the potentiometers and the problem stays with the same burner that does not light...
What can i do next ..... thank you
P.S. this is one of the XLO burners:rolleyes:
#2 Posted : 15 years ago
Does it click and/or spark when you turn it ON?
bobirino
#3 Posted : 15 years ago
bobirino
yes it does click as do all of them. there is no gas going into the burner.
thank you for answering..........
#4 Posted : 15 years ago
Looks like the problem is a bad solenoid or a bad simmer control. You have to perform the troubleshooting as described in the attached file.
Here are the breakdown diagrams and Replacement parts for THERMADOR PRSG304 | AppliancePartsPros.com
File Attachment(s):
bobirino
#5 Posted : 15 years ago
bobirino
Thank you so much, I'm on the case and will let you know how things work out.....
bobirino
#6 Posted : 15 years ago
bobirino
ok, and thanks for all of your help. now i have another situation in that i can not find the gas simmer control valve model #SQ003 for my oven/range.. any help out there? thanks in advance:rolleyes:
PS Thermador claims that they do not have this or a replacement for it....YIKES. what am i suppose to do? take it to the curb for trash pick up?
i think i found it thanks to gene. bosch ap3672574
bobirino
#7 Posted : 15 years ago
bobirino
Well I've finally had the time to replace the new simmer control and we have the same problem. What's next?
#8 Posted : 15 years ago
Have you checked the solenoid for this burner?
If you had, what was the result?
bobirino
#9 Posted : 15 years ago
bobirino
Can you send me a spec sheet to locate and check it. Any additional info would be helpful. Thank you, Bob.
bobirino
#10 Posted : 14 years ago
bobirino
hey gene, what does it take to check the solenoid?
Kenmore Oven Bottom Burner Will Not Light (Oven Repair (including Ranges and Cooktops))
by kfost 14 years ago
Magic Chef range oven burner will not light (Oven Repair (including Ranges and Cooktops))
by cdavis2260 14 years ago
Gas dryer burner will not light (Dryer Repair)
by Mike Chapman 16 years ago
Gas Oven Burner Will not light (Oven Repair (including Ranges and Cooktops))
by Matthew Wakefield 17 years ago
2 Pages12>
