moblo1@sbcglobal.net
#1 Posted : Friday, February 19, 2010 9:45:11 AM(UTC)
Oven will only work in self cleaning mode only. The bake light comes on but oven will not light.
#2 Posted : Friday, February 19, 2010 5:54:04 PM(UTC)
Check the Bake igniter (#28 on the diagram) for continuity. Check if there is 120 VAC to the Bake igniter while the control calls for Bake. Post the results.
- The oven igniter Part number: AP2014008
#3 Posted : Sunday, February 21, 2010 11:22:48 AM(UTC)
I checked the continuity in the ignitor. That is ok. The oven only lights in the self cleaning mode. What do I check next?
#4 Posted : Monday, February 22, 2010 12:45:05 PM(UTC)
You did the first part of the test. Did you do the second part?
#5 Posted : Thursday, February 25, 2010 9:44:05 AM(UTC)
When turning on the oven there is no voltage at the ignitor, but when turning the dial to self cleaning, the voltage comes on. what part should I replace?
#6 Posted : Thursday, February 25, 2010 5:18:06 PM(UTC)
Most likely the problem is a bad control board. It comes without overlay which has to be ordered separate. If you need the correct part number for the overlay, post the color of it.
- The control board Part number: AP2020510
Troubleshoot Self cleaning oven (Oven Repair (including Ranges and Cooktops))
by mluster1 2/27/2014 9:35:20 AM(UTC)
self cleaning oven problem (Oven Repair (including Ranges and Cooktops))
by preachergirl09 9/8/2013 11:20:21 AM(UTC)
Whirlpool Self Cleaning oven died after cleaning (Oven Repair (including Ranges and Cooktops))
by lmcd 1/15/2012 10:28:19 AM(UTC)
Self Cleaning Oven (Oven Repair (including Ranges and Cooktops))
by csimons 4/30/2010 4:28:17 PM(UTC)
self cleaning oven not working (Oven Repair (including Ranges and Cooktops))
by johnchapman@eastlink.ca 4/30/2010 6:54:50 AM(UTC)
Self cleaning ovens broken (Oven Repair (including Ranges and Cooktops))
by robertglick 4/21/2010 2:50:28 PM(UTC)
1970's frigidaire gas self cleaning oven unlock (Oven Repair (including Ranges and Cooktops))
by kelsmail2001 7/15/2009 4:30:12 AM(UTC)
Clock/timer Display Meltdown While Self Cleaning Oven (Oven Repair (including Ranges and Cooktops))
by WANAGO 5/14/2009 7:40:23 AM(UTC)
by kpeek22 3/24/2009 1:56:08 PM(UTC)
frigidaire self cleaning oven problem (Oven Repair (including Ranges and Cooktops))
by kathleenjones03@yahoo.com 3/14/2009 11:11:31 AM(UTC)
whirlpool self cleaning oven displaying 5fuse (Oven Repair (including Ranges and Cooktops))
by coachiewife 2/8/2009 6:45:45 PM(UTC)
by bullockla 1/20/2009 12:59:08 PM(UTC)
by upjmom 8/26/2008 7:19:12 AM(UTC)
kenmore self cleaning oven w/controle pad (Oven Repair (including Ranges and Cooktops))
by mttconway 5/8/2008 7:52:44 PM(UTC)
30" Electric Built-in Self Cleaning Oven (Oven Repair (including Ranges and Cooktops))
by jhoxendine 1/20/2008 7:57:33 AM(UTC)
