I need to replace the timer on this dryer and came accross 2 options. 1 with a clutch and 1 with out a clutch. Obviously the more expensive on is w/out the clutch. The owners manual is not inside control panel. Which one should I buy? Thanks
Tim
From the photos, it appears the two timers are distinctly different. I would go with the one that matches the one you have in your machine.
Hi Magician59, Thank you for the reply. From the pictures that I see, they are exactly the same as the part from the machine. I can't tell any difference. I do see on the old part, handwritten number, 33002803. Would this help deciding to buy the clutch or not? Thanks again, Tim Originally Posted by: magician59 From the photos, it appears the two timers are distinctly different. I would go with the one that matches the one you have in your machine.
