3 Pages<123
stlawerence
#21 Posted : Tuesday, January 26, 2010 9:23:29 AM(UTC)
stlawerence
If I got it clear, then you measured the temperature probe resistance at the plug which plugs into the EOC and such reading means there is a problem with the probe wire harness or (most likely) the probe harness plug at the probe.
I unplugged the wire harness from the EOC (to completely eliminate the harness and temp probe from the picture) and then measured the resistance between the two pins (which had high resistance). I then unplugged the wire harness from the temp prob (again, eliminating it from the picture) and it measured good resistance. I really didn't measure anything through the wire harness, should I do that?
I figured if I got good reading from the EOC only and the temp prob only, then I would check the wire harness to see if that was the problem. But since it measured the EOC was the problem, I didn't bother with checking the harness.
-Aaron
#22 Posted : Wednesday, January 27, 2010 12:59:49 PM(UTC)
Aaron,
The resistance reading between the pins on the EOC does not mean anything in this situation. On the other side, the resistance reading at the plug which is connecting into the EOC is very important and should match exactly with the reading at the temperature probe. If it does not, then there is a problem with the wire harness.
stlawerence
#23 Posted : Wednesday, January 27, 2010 5:00:22 PM(UTC)
stlawerence
Aaron,
Hi Gene,
Sorry, I mistook the earlier advice you gave in the thread
Check the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control).
It suppose to be about 1100 Ohms at the room temperature.
as being the two pins on the EOC. I'll check the plug which is connecting into the EOC to verify the harness. If this reading is OK, then the EOC is bad (correct?). If its doesn't match what I read at the temp probe, then it's the harness (correct?).
Thanks for all the assistance.
-Aaron
stlawerence
#24 Posted : Saturday, January 30, 2010 4:19:23 AM(UTC)
stlawerence
Gene,
The harness checked out fine. I was able to get an EOC from Appliance Parts and replaced it last night. That resolved the problem. Thanks for all your help!
-Aaron
#25 Posted : Saturday, January 30, 2010 4:49:13 PM(UTC)
gas range fault F 10 (Oven Repair (including Ranges and Cooktops))
by ddlong 9/13/2010 9:32:25 AM(UTC)
Can I use 20w bulbs instead of 10w to light cooktop? (Microwave Repair)
by Daniel J 2/28/2010 4:22:05 PM(UTC)
LG Electric dryer will not shut off 10 seconds after starting (Dryer Repair)
by miketieman 1/8/2010 3:02:54 PM(UTC)
Kenmore Wall Oven F 10 Fault (Oven Repair (including Ranges and Cooktops))
by Bigben 1/18/2009 10:46:53 AM(UTC)
Water Heater Relays click on/off 10-20 times (General Talk)
by markwrightjohnson 11/16/2008 11:44:23 AM(UTC)
Oven temp off 100 degrees (Oven Repair (including Ranges and Cooktops))
by S Brown 10/30/2008 6:44:37 AM(UTC)
3 Pages<123
