When finished using oven and the timer, a short while later the"beeping starts" and I get fault F 10. What is causing this? What part is needed? I tried turning off the breaker for awhile and even pushed "reset" but problem still exists.
Originally Posted by: ddlong ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) When finished using oven and the timer, a short while later the"beeping starts" and I get fault F 10. What is causing this? What part is needed? I tried turning off the breaker for awhile and even pushed "reset" but problem still exists. DD, The F10 code on your unit indicates a bad oven temperature sensor. Part number: AP3969435
Did this start occurring after a self clean cycle ? Did you notice if you had any overheating, cooking problems ? have you got tools and a meter to access and check the resistance of the temp. probe ? :cool: :cool: :cool:
Originally Posted by: ddlong ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) When finished using oven and the timer, a short while later the"beeping starts" and I get fault F 10. What is causing this? What part is needed? I tried turning off the breaker for awhile and even pushed "reset" but problem still exists. DD, Based on the manufacturers information, You most likely have a bad oven temperature sensor
