fordpickupgirl
#1 Posted : Friday, January 8, 2010 3:41:11 PM(UTC)
fordpickupgirl
Washer will not stop filling with cold water even when full. Is this something I can replace or do I need repair man?
#2 Posted : Saturday, January 9, 2010 4:35:25 AM(UTC)
I cannot find any info using the given Model Number.
Whirlpool numbers are usually 3 letters then a few numerarls then a letter/numeral mix.
Please check it
Model Number Locator
Your problem could be a couple things.
If unplugging or shutting of the unit off stops it filling, then the problem is probably the water level switch.
If the only way to stop it is by turning off the tap, then it is probably the water inlet valve (sticking open)
Water Level Switch
This switch is actually a pressure switch. It has a tube that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch's set point then the switch activates turning off the water and starting the agitate.
Possible problems.
1. Gunk blocking water from entering the tube. Remove the tube at the switch and blow into it to clear the plug.
2. Cracks or holes in the tube allowing the air to escape. Inspect the tube. Also check that it is tight on the switch, if not, cut off half an inch and re-seat it.
3. The switch is toast. Get a piece of tubing with the same internal diameter and attach this to the switch. Start a fill, then blow into the tube. You should be able to stop the water flow without blowing very hard.
If you cannot stop it the switch is toast.
fordpickupgirl
#3 Posted : Saturday, January 9, 2010 10:49:22 AM(UTC)
fordpickupgirl
Model#LSR8244DQO I think it is the water inlet valve from your description. Is this easy to replace or do I need special tools for this?
#4 Posted : Saturday, January 9, 2010 11:48:59 AM(UTC)
Here is the parts breakdown
Replacement parts for WHIRLPOOL LSR8244DQ0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203948172.pdf
No out of the ordinary tools should be required.
mstrixyrose@yahoo.com
#5 Posted : Wednesday, June 12, 2013 8:25:52 AM(UTC)
OH this was so easy for me.... I went to Washer is Overfilling - How to Repair - YouTube and when I went to my machine. Took out the 2 retaining screws that held the control panel on the top of the machine.... I lifted the panel and there it was.... the clear hose came off... I lightly blew through the hose no restriction. Plugged it back into the water level control switch... selected small load turned it on water flowing started to agitate then I switched to the med load and when it engaged washing I went to large. Now I have a load of laundry washing and no worries. I love YouTube for fixing things. I used it before too when I had a coup-link that broke and I had water flowing onto the floor from under the washer.... I found my parts on ********** and it was cheaper than going to a repair place or buying direct from the manufacturer. Good luck all.
#6 Posted : Wednesday, June 12, 2013 8:27:28 AM(UTC)
OH this was so easy for me.... I went to Washer is Overfilling - How to Repair - YouTube and when I went to my machine. Took out the 2 retaining screws that held the control panel on the top of the machine.... I lifted the panel and there it was.... the clear hose came off... I lightly blew through the hose no restriction. Plugged it back into the water level control switch... selected small load turned it on water flowing started to agitate then I switched to the med load and when it engaged washing I went to large. Now I have a load of laundry washing and no worries. I love YouTube for fixing things. I used it before too when I had a coup-link that broke and I had water flowing onto the floor from under the washer.... I found my parts on e bay and it was cheaper than going to a repair place or buying direct from the manufacturer. Good luck all.
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool washer F20 code (Washer Repair)
by wstrick14 1/6/2024 3:42:34 PM(UTC)
Whirlpool washer clicking when filling (Washer Repair)
by RogeM 12/3/2023 8:13:49 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
whirlpool washer buzzer Way too loud! (Washer Repair)
by Guest 5/1/2023 11:33:43 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Whirlpool washer spins during drain cycle (Washer Repair)
by jsdscot 1/23/2023 5:04:07 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
whirlpool washer fill and drain only (Washer Repair)
by Randero 10/14/2022 2:53:13 AM(UTC)
Capacitor for Front Load Whirlpool washer Model # wfw9550ww00 (Washer Repair)
by Guest 9/11/2022 2:49:05 PM(UTC)
