Doing a wash I noted the washer started a rithmic "clicking" at the start of a cycle. While "clicking" the washer will fill with water, then it seems that it wants to agitate but doesn't. It then adds more water and tries to agitate. It repeats this a few times. At this point, I shut it off. Did a drain & spin which worked fine. Checked online and found the instruction on the electronic sensor "reset" which I ran a couple of times. Starting over I get repeating "click" while filling with water which gets me back to the above steps. Thanks in advance for your advice. Edited by user Sunday, December 3, 2023 9:47:51 AM(UTC)
| Reason: Not specified
