One year old coin op unit will fill, do nothing for 15 min. drain and refill, then do nothing for 15 min. then drain and in a bit the done light comes on. Front panel lights go through all the cycles. Lid lock light never comes on and lid does not lock. Belt is good and in place. During first fill it will give an occasional 2 second agitator movement.I do have a good shift actuator i can swap.lid switch will not lock, it sucks in but wont lock in place yet the unit goes through the cycles. Am I not seeing/accepting the obvious?
