grassroots
#1 Posted : Sunday, December 20, 2009 5:09:59 AM(UTC)
grassroots
technician says thermostat ok, so the poor heating (100degrees) low would have to be the control panel. Replaced control panel and key pad would not work. Says we need a new key pad. Replaced. Went to use it for baking last night for the first time (8hours later) and found out it isn't heating any better. Still a (100 degrees) low. This appliance company recommended by Kitchen Aid. What's the problem?
#2 Posted : Monday, December 21, 2009 4:18:49 AM(UTC)
Replacement parts for WHIRLPOOL KEHC309JSS4 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%204453233.pdf
Here is a manual which may be helpful
https://secured.whirlpoo...539256/$FILE/MWCOMBO.PDF
What's the problem?
By the sound of it the service tech is the biggest problem. Any person who replaces parts and then does not check the unit is not much of a technician and it does not sound like a check was done
I am assuming that the oven does preheat and come ready.
Check that all the elements are OK looks like the unit uses Bake, Inner Broil and Outer Broil for preheat but only the Bake and Outer Broil for baking.
Perhaps the Bake or Outer Broil is shot and the unit cannot maintain the temperature. Usually during bake they switch between the elements rather than have them all on at once but I could not confirm this.
I would re-check the thermostat. Here is a good site, check out 7, 8, 20 and 21.
http://www.applianceaid.com/elecrange.html
I hate to diss a tech without actually being there but this sounds like he/she messed something up when disconnecting the keypad from the control board re: did not unlock it before removal see page 2-3 in the manual or something like this.
Then get back in touch with Kitchen Aid and raise hell.
gary (Dryer Repair)
by gaseidletz@gmail.com 3/26/2013 1:57:49 PM(UTC)
gary (Refrigerator & Freezer Repair)
by gaseidletz@gmail.com 8/15/2012 1:49:28 AM(UTC)
gary (Oven Repair (including Ranges and Cooktops))
by gaseidletz@gmail.com 8/3/2012 4:23:23 PM(UTC)
Gary (Washer Repair)
by gary2 12/5/2011 10:42:42 AM(UTC)
Gary Grummer (Oven Repair (including Ranges and Cooktops))
by Gary Grummer 12/4/2011 1:28:49 PM(UTC)
by gary2 11/12/2011 7:21:33 PM(UTC)
Gary Allen (Oven Repair (including Ranges and Cooktops))
by ringo 6/19/2010 8:50:19 AM(UTC)
by GSCHMIDT 6/11/2010 7:38:41 AM(UTC)
Garyp123 (Washer Repair)
by garyp123 5/6/2010 10:19:35 AM(UTC)
Gary (Microwave Repair)
by adcon@satx.rr.com 4/9/2009 10:35:24 AM(UTC)
by gary g 2/2/2009 5:56:57 AM(UTC)
Gary Jaeger (Oven Repair (including Ranges and Cooktops))
by Gary Jaeger 1/9/2009 9:28:01 AM(UTC)
garylee (Microwave Repair)
by garylee 9/8/2008 6:18:27 PM(UTC)
