clock/timer/oven display lights up,when you turn any of the burners on(smooth top range)a small indicator lite comes on that burner is on however none of the burners will heat up plus neither the oven or broiler will heat NOTE:my son just purchased home and range came with it so we dont know history of range. Any help as to whats wrong greatly appreciated.
You folks are great. I removed back and went to terminal block as you suggested. Found 2 loose wires and 1 disconnected,made repair and now everything on range works great. Many thanks; Gary
