I have Maytag Neptune electric dryer, model # (P) MDE9700AYW. It will have squeak/noise when you start it with a load in it then stops after it runs for a little while. It mostly happens with a larger/heavier load in dryer but does not do it every time. My question is if it's probably the belt or could it be a pulley or bearing? I would appreciate any help you could give me on the problem. Thank you
Hello, The problem can be a bad drum support rollers, a bad idler pulley, a bad motor or a bad drum. It's hard to guess which part to order without taking the dryer apart and inspecting all parts. Here are the breakdown diagrams and Parts for Maytag MDE9700AYW Dryer - AppliancePartsPros.comGene.
