I turn my dryer on the automatic permanant press or regular cycle and it is stuck in the same position and doesn't shut off until I do it manually, it also takes at least an hour for the clothes to dry. I just replaced the timer and thought that would fix it but it didn't. Can someone tell me what to do. :confused: (Maytag Atlantis)Thanks a bunch!
it's probably your operating stat
Also I would check the exhaust for possible clog.
:rolleyes: Originally Posted by: cspires ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I turn my dryer on the automatic permanant press or regular cycle and it is stuck in the same position and doesn't shut off until I do it manually, it also takes at least an hour for the clothes to dry. I just replaced the timer and thought that would fix it but it didn't. Can someone tell me what to do. :confused: (Maytag Atlantis)Thanks a bunch!
Hi - Thanks for posting your problem, I've got the same issue. Did you ever resolve this problem? Thanks
Originally Posted by: roycreamer ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) it's probably your operating stat What is the operating stat?
Not yet, but I will keep you informed.
