washind
#1 Posted : Monday, February 25, 2008 3:30:56 PM(UTC)
washind
The oven light magically turned on and won't shut off. Disconnected power for 5 minutes with no effect.
Any tips would be appreciated.
Thanks...Dave
#2 Posted : Tuesday, February 26, 2008 1:25:34 PM(UTC)
Hi Dave,
The model number you posted is not a valid Whirlpool model number.
Verify and repost it, please.
washind
#3 Posted : Tuesday, February 26, 2008 3:05:19 PM(UTC)
washind
Thanks Gene, the range is a Whirlpool Gold (Canadian) GLP-85800. Since I posted, I tested the wiring and door switch and all is ok there. I suspect a bad relay on the main board, but since the light(s) remain on, I simply installed another switch in series that seems to do the trick.
Thanks ...Dave
#4 Posted : Tuesday, February 26, 2008 4:30:39 PM(UTC)
Dave,
I'm glad you were able to fix it.
Oven light stays on constantly (Oven Repair (including Ranges and Cooktops))
by caballin39 11/15/2009 12:11:47 PM(UTC)
