rrauhut
#1 Posted : Tuesday, November 10, 2009 4:31:29 PM(UTC)
rrauhut
I'm trying to determine what the issue is with this dryer. When running in the Low heat or High heat cycles it's getting way too hot. So hot it smells like something is burning. I've cleaned out the venting system and have even ran it without the hose connected and get the same result. I've researched this a little and looks like it might be the cycle thermostat?? I guess I'm just looking for confirmation. Could it be the heating element on it's way out? Thanks in advance.
#2 Posted : Wednesday, November 11, 2009 3:33:25 AM(UTC)
A Model Number may help. You need a wiring diagram so you can see how the temperatures are set/regulated.
This is a possibility
No.
But it could be a grounded element. The element has sagged or broken and is touching the case so that it runs all the time regardless of what the thermostat is doing.
rrauhut
#3 Posted : Wednesday, November 11, 2009 6:17:25 PM(UTC)
rrauhut
Hey thanks denman, The model number is TEDS740PQ0. I'll search for a wiring diagram but it's all kind of foreign to me. I've looked at the element and I don't notice any individual broken elements or and sagging touching the casing. But the casing looks toasted on one half while the other side looks fine. I don't know if that's just a result of the whole thing getting too hot or if just that part of the whole element is getting too hot. Thanks for your help in advance.
#4 Posted : Thursday, November 12, 2009 5:50:03 AM(UTC)
Replacement parts for WHIRLPOOL TEDS740PQ0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208528187.pdf
When you had it off the vent did you check the air flow?
Sometimes blower wheel can come loose/crack and slip on the motor shaft.
Check that the seals etc. in the air path are OK.
The blower pulls air over the heating coil then trough the drum and pushes it out the exhaust. If there is a leak before the blower where the operating thermostat is mounted it will run hotter than it should.
It is a possibility that the operating thermostat is bad, especially when high heat and low heat both run too hot.
If you do decide to change it make sure that you note where the wires go. This is a 4 wire thermostat, 2 fot it's contacts and 2 for it's internal heater.
rrauhut
#5 Posted : Wednesday, November 18, 2009 4:26:17 PM(UTC)
rrauhut
The airflow is good so I think we're fine there.
When you say the operating thermostat...are you referring to this part?
Part Number WHIRLPOOL AP3131941 - Thermostat, fixed,
Thanks again for all the help.
#6 Posted : Thursday, November 19, 2009 1:40:19 AM(UTC)
No, this is the hi-limit thermostat
The operating (cycling) thermostat is AP3131939 Item 8 in Section 1.
Part number: AP3131939
rrauhut
#7 Posted : Monday, November 23, 2009 3:23:46 PM(UTC)
rrauhut
Well, I replaced the operating (cycling) thermostat and it's still running too hot. When I start it up after about 90 seconds it starts to smell like it's burning. Any other ideas?
#8 Posted : Monday, November 23, 2009 3:49:08 PM(UTC)
Did you check for a grounded element as mentioned in my first post?
rrauhut
#9 Posted : Tuesday, November 24, 2009 4:17:08 AM(UTC)
rrauhut
Yeah, as far as I can tell the elements look good. There isn't one that looks out of place or touching anything else. But the piece of metal that divides the two sides of the element is black on one half. So maybe one half of the element is getting too hot. Have you heard of this before? Again thanks for all the help.
#10 Posted : Tuesday, November 24, 2009 5:12:59 AM(UTC)
No.
I would think that if it is black either something has gotten into the heater and burned (re: lint etc.) or it has arced/sparked to the case.
Guest (5)
Dryer too hot flips the thermal fuse (Dryer Repair)
by Maverick1 12/6/2017 6:29:07 AM(UTC)
Frigidaire Dryer Too Hot and doesn't stop on Auto (Dryer Repair)
Belarus rgrandmaison5@gmail.com 11/16/2014 3:00:14 PM(UTC)
whirlpool dryer too hot (Dryer Repair)
by nurse_amy1@live.com 10/16/2014 1:02:40 PM(UTC)
by MWIDONNA 10/15/2014 4:51:36 PM(UTC)
Kenmore Dryer too hot (Dryer Repair)
by jsamp05 8/11/2013 12:11:50 PM(UTC)
Whirlpool gas dryer too hot (Dryer Repair)
Belarus dorkfart 8/1/2013 6:56:43 AM(UTC)
dryer too hot (Washer Repair)
by ray4005 6/23/2012 10:19:59 AM(UTC)
dryer too hot on perm press cycle (Dryer Repair)
by jerrydc 6/20/2012 11:09:45 AM(UTC)
Dryer too hot and not cooling down (Dryer Repair)
by msbee03 6/13/2012 11:46:21 AM(UTC)
Whirlpool electric dryer too hot (Dryer Repair)
by Fixnitmyself 5/16/2012 12:36:00 PM(UTC)
GE dryer too hot (Dryer Repair)
by cap10chris 3/18/2012 4:22:45 PM(UTC)
Dryer too hot then quit (Dryer Repair)
by Jon Sims 1/16/2012 7:16:06 AM(UTC)
by indycraft 4/28/2011 12:09:53 PM(UTC)
dryer too hot? (Dryer Repair)
by jamiemad1 4/8/2011 12:30:54 PM(UTC)
by Alina0212 4/1/2011 11:07:07 AM(UTC)
