msbee03
#1 Posted : Wednesday, June 13, 2012 11:46:21 AM(UTC)
msbee03
Workign on a frigidaire dryerthat is getting too hot and not cooling down. I found a faulty control board and replaced it corrected the problems for a few months, but now it is doing it again. The board wasn't cheap, is there something I am over looking I should be investigating? Any help would be appreciated. Thanks!:confused:
#2 Posted : Thursday, June 14, 2012 10:32:17 AM(UTC)
Originally Posted by: msbee03 Go to Quoted Post
...a frigidaire dryerthat is getting too hot and not cooling down...
Can you describe it more detailed please?
Did it show any error codes?
msbee03
#3 Posted : Thursday, June 14, 2012 12:38:12 PM(UTC)
msbee03
No it is a basic dryer.Just dial and buttons. . The dryer in any cycle heats fine, but when it goes through the cool down in any cycle it just stays hot and continues until it shuts off. Clothes are hot. Would a bad heating element cause this? Thanks.
#4 Posted : Thursday, June 14, 2012 3:07:37 PM(UTC)
...No it is a basic dryer.Just dial and buttons...
That's not right. It's shown at the diagrams that this dryer operates by the electronic control (#1 at the diagram).
Quote:
...Would a bad heating element cause this?...
Yes, it would if the heating element is shorted to the ground. You have to unplug the dryer, remove the wires from the heating element and check for continuity between each terminal and the ground.
- The heating element coils Part number: 5300622034
- The heating element assembly Part number: 131553900
msbee03
#5 Posted : Thursday, June 14, 2012 3:21:01 PM(UTC)
msbee03
Thank you, it is definitely the heating element that was the cause. Thanks for your help!
