DIYMom2
#1 Posted : Tuesday, October 6, 2009 4:10:40 PM(UTC)
DIYMom2
Does anyone have detail instructions on how to change the motor coupler in my Kenmore washer? I see it is broken but can't see how to get to it. Already have the part. Also when I removed the three screws holding the motor on and pulled on it for it to only come so far, there was some oil that leaked out. So need to know how to put oil back in the motor too.
Any help is greatly appreciated.
sidfink43
#2 Posted : Wednesday, October 7, 2009 9:41:55 AM(UTC)
sidfink43
Hi DIYMom2
You have us a little confused because the motor is not held on with three screws, but with two clips, so we are not sure what you took off or why oil came out of it.
Anyway, here is a video which will show you how to change out the coupling, and if you can identify what you took off with the three screws maybe we can help you there.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
Three screws do take out the transmission, and that is where oil is, so is that what you tried to take out?
DIYMom2
#3 Posted : Wednesday, October 7, 2009 1:45:14 PM(UTC)
DIYMom2
Yes. I believe you are correct. It is directly beneath the wash drum. Thank you for the video tutorial.
DIYMom2
#4 Posted : Wednesday, October 7, 2009 2:26:33 PM(UTC)
DIYMom2
I just went out to fix the washer after viewing the video and I have one problem. The very first step: There are no screws visible that would allow me to tilt the control panel open to gain access to the clips that hold the back on. Now what?
sidfink43
#5 Posted : Wednesday, October 7, 2009 2:55:56 PM(UTC)
sidfink43
Ok, if the screws are not on the back, or under trim pieces then you apparently have a newer model that does not have the screws. In your case you need to insert a think flat putty knife under the console in the gap between the console and the top near each edges. This will release clips which hold the console down. Sometimes you have to push with a fair amount of force, but be careful not to scar your machine.
Be patient, it may take a little bit of trial and error to find them and release them, but that should do it.
Motor coupler keeps breaking (Washer Repair)
by Tobyiscute 1/25/2016 8:27:49 AM(UTC)
Burning smell after replacing motor coupler (Washer Repair)
by Beerman_Supreme 6/8/2011 3:56:54 AM(UTC)
Motor Coupler (Washer Repair)
by madikenn 5/17/2011 7:50:54 PM(UTC)
Squealing noise after changing Motor Coupler (Washer Repair)
by DanPizano 4/10/2011 11:06:41 AM(UTC)
by Moxleysr 2/4/2011 7:09:14 AM(UTC)
Washer, Kenmore 90Series Replaced motor coupler, now makes very loud noise/whistle (Washer Repair)
by Allen74 10/22/2010 12:12:20 PM(UTC)
how do you know if the motor coupler is bad? (Washer Repair)
by LHERD 12/26/2009 5:52:25 AM(UTC)
new motor coupler doesn't fit (Washer Repair)
by TDM 12/4/2009 2:41:55 PM(UTC)
Need info for replacing motor coupler (Washer Repair)
by uijongbu72 6/7/2009 11:06:17 AM(UTC)
