RepDry
#1 Posted : Wednesday, September 23, 2009 4:48:25 PM(UTC)
RepDry
The dryer does not heat. Everything else seems to work. The fuse, thermostats and heating element all have continuity. How do I check the timer knob? At the top 3 terminals, there is continuity between the middle terminal and each of the outer terminals, but not between the outer ones. Since these are the ones that had the heavy wires attached, I assume these are the ones that go to the heating element.
glen65
#2 Posted : Wednesday, September 23, 2009 7:04:13 PM(UTC)
glen65
The first thing that needs to be checked is the voltage
where the dryer cord hooks up to the back of the dryer.
You should be getting 240 volts AC between the outside
two terminals. Then 120 between the center and the others.
UserPostedImage
RepDry
#3 Posted : Thursday, September 24, 2009 6:03:04 PM(UTC)
RepDry
Thanks. I will not have time to check that for a few days, but I will.
Kenmore dryer not heating (Dryer Repair)
by jpdkrty 8/13/2016 3:50:00 PM(UTC)
Kenmore dryer not heating properly (Dryer Repair)
by yyzt4e 7/8/2015 4:58:45 PM(UTC)
Kenmore Dryer Not Heating After We Did Changed the Rear Drum Felt Seal (Dryer Repair)
by kytre 6/2/2015 7:25:49 PM(UTC)
Kenmore Dryer not heating (Dryer Repair)
by bkenner 3/23/2014 5:42:55 PM(UTC)
by Drichie 5/21/2013 3:29:30 PM(UTC)
Kenmore dryer not heating - next steps? (Dryer Repair)
by bangelus 12/6/2012 5:59:36 AM(UTC)
by murphy7513 7/4/2012 8:17:34 PM(UTC)
by PIO_ACA_CMY 1/5/2012 3:23:10 PM(UTC)
kenmore dryer not heating (Dryer Repair)
by bwoltanski 12/27/2011 9:01:29 AM(UTC)
by Dando 6/18/2011 12:45:41 PM(UTC)
by TexFordD 3/20/2011 10:15:14 AM(UTC)
by JaxMax 3/14/2011 9:11:16 AM(UTC)
by MBKENMORE 9/8/2010 10:00:42 AM(UTC)
by lego1231 9/21/2009 8:18:43 AM(UTC)
Electric Kenmore Dryer not heating (Dryer Repair)
by morenojx 9/2/2009 7:32:58 AM(UTC)
