tyount
#1 Posted : Wednesday, August 26, 2009 3:48:20 PM(UTC)
tyount
All functions appear to work. It fills, agitates, drains, and spins. However, it will agitate immediately upon starting to fill and adds water during the final spin cycle, thus leaving the clothes wetter when done. There are no unusual sounds. Any ideas?
richappy
#2 Posted : Thursday, August 27, 2009 7:09:58 AM(UTC)
richappy
I would check the water level switch. Remove the plastic hose to it and blow in it to clear it out. Check the other end where it goes into the tub, clear out any soap residue with vineger.
tyount
#3 Posted : Friday, August 28, 2009 7:35:26 AM(UTC)
tyount
The entire hose is clean including both connecting ends. What next?
richappy
#4 Posted : Friday, August 28, 2009 8:29:46 AM(UTC)
richappy
Does it act up on any cycle? To help further, I need the complete model #
tyount
#5 Posted : Friday, August 28, 2009 9:01:27 AM(UTC)
tyount
Kenmore mod# 11023022101 On all cycles, it will instantly agitate as it begins to fill with water. Normally the tub will fill with water first as you add soap and clothes, then begin to agitate when the water is at the proper level. It also appears to spray or add water to the final spin, and therefore the clothes are not as dry as normal. These two symptoms began at the same time.
richappy
#6 Posted : Friday, August 28, 2009 10:14:00 AM(UTC)
richappy
Sounds like a bad timer. If it has a metal cover, remove it and check for burnt/welded shut contacts. If it looks ok, just replace it. You can order it on this parts site.
tyount
#7 Posted : Friday, August 28, 2009 10:49:15 AM(UTC)
tyount
Thanks, I have one on order from your site.
gvreimer
#8 Posted : Wednesday, January 5, 2011 9:39:21 AM(UTC)
gvreimer
I have the exact same problem. Did you ever find out the cause? Was it the timer? Thanks!
Timer problem? (Washer Repair)
by johnvbf 1/6/2017 11:44:13 AM(UTC)
Whirlpool EHT 201 OLD!!! Defrost Timer Problem? (Refrigerator & Freezer Repair)
by dsoelter 9/15/2014 3:42:07 PM(UTC)
Possible timer problem? (Dryer Repair)
by vorsk 2/26/2014 6:31:24 AM(UTC)
defrost timer problem? (Refrigerator & Freezer Repair)
by BSTrue 8/12/2013 3:12:50 PM(UTC)
Is this a washer timer problem? (Washer Repair)
by hanketron 4/18/2013 12:00:25 PM(UTC)
Timer Problem? (Dryer Repair)
by Grump 1/13/2013 7:15:30 AM(UTC)
Kenmore 600 Series Timer Problem? (Washer Repair)
by fedup352 5/3/2012 10:56:38 AM(UTC)
Maytag washer, timer problem? (Washer Repair)
by Rene' 9/1/2011 5:48:01 AM(UTC)
by butlermom9 2/21/2011 12:19:36 PM(UTC)
Kenmore Electric Dryer - Timer Problem?? (Dryer Repair)
by gus1 2/21/2011 8:55:50 AM(UTC)
Maytag timer problem? (Washer Repair)
by Aaron2010 6/24/2010 9:21:34 AM(UTC)
Timer problem???? (Washer Repair)
by sacto 10/12/2009 7:44:26 AM(UTC)
by Amamaman 8/25/2009 4:29:06 PM(UTC)
by dpeter33 6/22/2009 6:21:43 PM(UTC)
Timer problem?? (Washer Repair)
by eamiller 5/26/2008 1:49:20 PM(UTC)
