Ice bin is full. Water works fine. When you push on the ice dispenser button, only a hum is heard. No ice is dispensed. Any help would be appreciated...rusty
Remove the ice bin and empty it. Make sure it's clean and dry. Put it back, push the dispenser release and see how the motor works. If the problem is still exist then perform the motor troubleshooting as described in the Service manual and post the results. Gene.
Originally Posted by: Gene  Remove the ice bin and empty it. Make sure it's clean and dry. Put it back, push the dispenser release and see how the motor works. If the problem is still exist then perform the motor troubleshooting as described in the Service manual and post the results. Gene. Great manual! I've ordered a new motor. Should be the fix! thanks, rusty
