12 Pages«<34567>»
chang2225
#41 Posted : Wednesday, July 15, 2009 6:51:50 PM(UTC)
chang2225
Does anyone have diagram, or pictures, or video showing how to replace the handle?
I took off the top screw but have no access to the bottom screw.
chang2225
#42 Posted : Wednesday, July 15, 2009 8:37:59 PM(UTC)
chang2225
I just replaced the door handle successfully by referencing the pix and video from previous posting. Thanks to those provided information.
I referenced Admin/APP Team post dated 08-01-2007 with diagram. I used a table knife, gently pop open #2. Even though the diagram is not for GE, door assembly is about the same.
The top screw can be accessed from inside of the door. Bottom screw is hidden behind #2. Once #2 is removed, I unscrew the bottom screw then put on the new one.
If you have GE model diagram, it would be part #1805 to be popped out. Also, I purchased new handle from ******** with half the price quoted by GE.
Kendalls Mom
#43 Posted : Saturday, August 1, 2009 7:06:00 AM(UTC)
Kendalls Mom
Cracked handle owner here too :mad: Any advise on taking my door apart
GE profile JVM1860SD001? I'm willing to try it if its possible.
Thanks!
Carla
#44 Posted : Saturday, August 1, 2009 3:02:27 PM(UTC)
Carla,
You have to remove the inner door frame (#6 on the diagram). You can use the same instructions and video.
- The door handle Part number: AP3187471
Kendalls Mom
#45 Posted : Saturday, August 1, 2009 5:16:43 PM(UTC)
Kendalls Mom
Thanks a bunch!:)
#46 Posted : Saturday, August 1, 2009 5:50:51 PM(UTC)
Kendalls Mom
#47 Posted : Saturday, August 8, 2009 6:57:48 AM(UTC)
Kendalls Mom
Gene,
Thank you so much! I sucessfully replace the handle on my GE profile. Just a bit of advice to everyone. When you use the butter knife, use it on the sides that have studier material. On mine, the top was very thin so I pryed the side and one side of the bottom, then I was able to pull the top away.
I only had to pull one layer away. The handle is supposed to have two screws on top and two on the bottom. When I took off the first layer only one screw was exposed on the top and the bottom. We decided to not bother getting to the other layer to get the other two screws off.
Everyone's advice here saved me a bunch of $$ and aggrevation. Thanks!!
#48 Posted : Sunday, August 9, 2009 8:39:42 PM(UTC)
I'm glad you were able to fix it. Thank you for your feedback and good luck with your microwave.
dbardo1
#49 Posted : Saturday, August 29, 2009 10:47:18 AM(UTC)
dbardo1
I just purchased the #7 door handle to replace it on my Whirlpool Microwave MH1150XMS1 (Stainless). However, there is no #2 inner frame on the door diagram. How do I get to the inner screws? All other models show the inner frame on the door diagram except this one. Thanks in Advance.
UserPostedImage
#50 Posted : Saturday, August 29, 2009 3:40:01 PM(UTC)
Some of the door parts are not shown because Whirlpool does not sell them separate for this model. The access to the screws should be the same.
GE Profile #PVM917DFBB microwave handle removal (Microwave Repair)
by trifive 10/26/2019 10:36:24 AM(UTC)
microwave handle repair (Microwave Repair)
by rthill01 1/28/2013 3:06:37 PM(UTC)
Replacing microwave handle (Microwave Repair)
by gregx5 5/25/2011 11:39:20 AM(UTC)
Microwave handle (Microwave Repair)
by mrorvis 2/23/2011 3:23:42 PM(UTC)
Microwave handle repair (Microwave Repair)
by rburton61 11/26/2010 9:59:01 AM(UTC)
microwave handle broke off (Microwave Repair)
by bigbro 12/9/2009 6:41:06 AM(UTC)
Installing Microwave handle (Microwave Repair)
by Buckey1 5/12/2009 4:17:22 PM(UTC)
by gdevas 4/29/2009 2:40:29 PM(UTC)
Microwave Handle (Microwave Repair)
by tyohe@yoheconsulting.com 4/1/2009 9:49:31 AM(UTC)
Kenmore microwave handle repair (Microwave Repair)
by ginasal 3/20/2009 7:23:07 PM(UTC)
Broken off GE Microwave Handle pn #AP3187809 (Microwave Repair)
by mrbotto 2/7/2009 2:37:37 PM(UTC)
Microwave Handle replacement (Microwave Repair)
by Yusuf 2/6/2009 1:55:27 PM(UTC)
Install GE Microwave handle (Microwave Repair)
by icandoitmyself454 2/5/2009 4:43:55 PM(UTC)
How to install new microwave handle (Microwave Repair)
by Chalcook 12/23/2008 3:33:31 PM(UTC)
GE Microwave Handle Replacement (Microwave Repair)
by Graham Brown 12/14/2008 9:32:23 AM(UTC)
12 Pages«<34567>»
