Does anyone have diagram, or pictures, or video showing how to replace the handle? I took off the top screw but have no access to the bottom screw.
I just replaced the door handle successfully by referencing the pix and video from previous posting. Thanks to those provided information.
I referenced Admin/APP Team post dated 08-01-2007 with diagram. I used a table knife, gently pop open #2. Even though the diagram is not for GE, door assembly is about the same.
The top screw can be accessed from inside of the door. Bottom screw is hidden behind #2. Once #2 is removed, I unscrew the bottom screw then put on the new one.
If you have GE model diagram, it would be part #1805 to be popped out. Also, I purchased new handle from ******** with half the price quoted by GE.
Cracked handle owner here too :mad: Any advise on taking my door apart GE profile JVM1860SD001? I'm willing to try it if its possible. Thanks! Carla
Gene, Thank you so much! I sucessfully replace the handle on my GE profile. Just a bit of advice to everyone. When you use the butter knife, use it on the sides that have studier material. On mine, the top was very thin so I pryed the side and one side of the bottom, then I was able to pull the top away. I only had to pull one layer away. The handle is supposed to have two screws on top and two on the bottom. When I took off the first layer only one screw was exposed on the top and the bottom. We decided to not bother getting to the other layer to get the other two screws off. Everyone's advice here saved me a bunch of $$ and aggrevation. Thanks!!
I'm glad you were able to fix it. Thank you for your feedback and good luck with your microwave.
I just purchased the #7 door handle to replace it on my Whirlpool Microwave MH1150XMS1 (Stainless). However, there is no #2 inner frame on the door diagram. How do I get to the inner screws? All other models show the inner frame on the door diagram except this one. Thanks in Advance.
Some of the door parts are not shown because Whirlpool does not sell them separate for this model. The access to the screws should be the same.
