The exaust fan runs at high speed only. Can you advise what part is needed. I assume the touch panel may be gone?. Thanks you George Madden
What it does when you try to switch on low speed?
Gene the fan stays on high when I hit the low speed button or any other button. Ours has a Fan boast button as well and hitting that doesn't make any difference either. Thanhks Again George Madden
George,
Does it beep?
Does it show anything on the display?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) George,
Does it beep?
Gene. Hi Gene Yes it beeps every time I hit the control button. The display shows high, medium and low speeds. Whe I hit the Boast button that shows in display also. I can't thank you enough for your expertise help. Sincerely George M
George, Most likely the problem is the control board (aka Printed Circuit Board). - The part number for the control board is AP3192717 - Here are the break down diagrams for the GE microwave Model JVM1860WD001Good luck. Gene.
Gene I can't thank you enough for your help it is most appreciated. If you could give me your email address I will let you know how I make out. Sincerely George M
George,
The Admin of this forum does not let us to post our e-mails.
Just post the results here and I'll see it.
