clyonsden1
#1 Posted : Tuesday, January 1, 2008 12:39:03 PM(UTC)
clyonsden1
Our dryer won't dry. We have replaced the heating coils and checked all of the the things mentioned in previous posts. What should the meter reading be at the heating coil?
richappy
#2 Posted : Tuesday, January 1, 2008 4:28:06 PM(UTC)
richappy
Should be around 11 ohms unplugged. Have you checked power to the dryer, should be 230 volts.
clyonsden1
#3 Posted : Wednesday, January 2, 2008 6:35:59 PM(UTC)
clyonsden1
I replaced the motor switch and I still have 120 v. to the heating coil, but no heat. Is this correct or should it be 240? The heating coil housing has two safety devices on it. The lower one checks to be closed with an ohm meter. The upper one creates no change on the meter when I check it, but if I run the machine, I get 120 v. through the device.
richappy
#4 Posted : Thursday, January 3, 2008 12:28:18 AM(UTC)
richappy
You have a blown thermal fuse, the one you measured 115 across it, pull it and verify with an ohms meter.
Roper RED4440VQ1 dryer won't dry well in auto sense (Dryer Repair)
by stwr250r@gmail.com 2/9/2019 6:46:32 PM(UTC)
Dryer won't dry replaced, coil, cycling thermostat high limit thermostat (Dryer Repair)
by Replacedeverythingindryer 2/17/2015 2:17:26 PM(UTC)
Whirlpool Gas Dryer Won't Dry (Dryer Repair)
by cellphone200 2/7/2013 10:02:43 PM(UTC)
Gas Dryer won't dry clothes (Dryer Repair)
by tubguy 11/16/2010 7:21:44 PM(UTC)
Gas Dryer won't dry clothew (Dryer Repair)
by tubguy 11/16/2010 7:12:58 PM(UTC)
Dryer won't dry comletely (Dryer Repair)
by AgileDarrell 4/19/2010 5:30:33 PM(UTC)
GE Dryer Won't Dry Clothes in One Cycle (Dryer Repair)
by pete1965 4/19/2010 7:56:02 AM(UTC)
Dryer won't dry (Dryer Repair)
by chevy47 3/1/2010 10:27:00 AM(UTC)
Kitchenaid dryer won't dry clothes completely (Dryer Repair)
by timandjulie 1/16/2010 9:25:13 AM(UTC)
by Patch010108 12/23/2009 8:41:53 AM(UTC)
Kenmore elite dryer won't dry clothers (Dryer Repair)
by abilene56 12/19/2009 9:58:18 AM(UTC)
by urdap 10/21/2009 9:54:49 AM(UTC)
Dryer won't dry. Only runs cold air. (Dryer Repair)
by momoftwynz 10/12/2009 6:28:01 PM(UTC)
Dryer won't dry clothes, NO HEAT (Dryer Repair)
by candace52979 6/21/2009 9:02:14 AM(UTC)
my ge dryer won't dry please help (Dryer Repair)
by jcannj 3/22/2009 5:01:46 PM(UTC)
