saw3c
#1 Posted : Tuesday, May 18, 2010 9:48:06 AM(UTC)
saw3c
My dryer will not heat so I tested the thermostat & I did get continuity. I tested the wires to the element while the unit was on with temp setting on high and no voltage.
What could it be? Could it be a fuse or part?
#2 Posted : Tuesday, May 18, 2010 5:09:49 PM(UTC)
The first thing I would do is check for 240 VAC at the wall outlet for the dryer. The heating element needs 240 VAC while the motor needs only 120 VAC.
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 12:28:50 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 8:33:52 AM(UTC)
Kenmore dryer will not heat (Dryer Repair)
by cfalter 9/29/2012 4:34:50 PM(UTC)
Kenmore dryer will not heat on second cycle (Dryer Repair)
by Jim G42 7/15/2012 12:18:17 PM(UTC)
Kenmore Dryer Will not heat (Dryer Repair)
by ajb1010 5/21/2012 2:36:03 PM(UTC)
Kenmore Dryer Will Not Heat Up (Dryer Repair)
by mastaone 11/8/2009 12:44:09 PM(UTC)
by vikingboy 9/25/2009 1:04:15 PM(UTC)
Kenmore dryer will not heat.3 weeks-- my wife is mad (Dryer Repair)
by topagent 7/31/2009 12:51:43 PM(UTC)
by lpennock 5/10/2009 3:56:08 PM(UTC)
Kenmore Dryer will not heat (Dryer Repair)
by T.A.M. 2/9/2009 5:29:54 PM(UTC)
