tvtaz
#1 Posted : Saturday, May 15, 2010 12:30:54 PM(UTC)
tvtaz
How would I know if I have to replace the motor? When you press the start button it makes a humming sound. The belt is taut around the drum soIdon't think that is the reason the drum isn't turning.
#2 Posted : Monday, May 17, 2010 1:50:58 AM(UTC)
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it.
If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp.
If nothing is jammed in there you will have to open it up and find the cause.
If it rotates OK.
This may take 2 people
Open the door
Manually hold the door switch closed
Push the start button and manually rotate the drum in the correct direction.
Watch your knuckles in case it starts up.
If it does start up, odds are high that you need a new motor.
Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit.
GE electric dryer (DCVH680EJ1MS) Stops 2 mins. Into Cycle (Dryer Repair)
by bjohns610 9/30/2019 2:15:08 AM(UTC)
GE electric dryer rotating switch (Dryer Repair)
by pamelaw72 8/21/2019 2:39:50 PM(UTC)
GE Electric Dryer Shuts Off Mid-Cycle (Dryer Repair)
by Dynocon 10/22/2015 5:20:00 PM(UTC)
GE Electric Dryer - Belt / slide fix, did I break something? (Dryer Repair)
by bmilcs 8/23/2015 1:23:57 PM(UTC)
GE electric Dryer running then had a smell and stopped (Dryer Repair)
by DDEAN 5/12/2015 7:52:33 PM(UTC)
GE Electric Dryer won't start (Dryer Repair)
by brosnan 12/13/2014 2:08:12 PM(UTC)
GE Electric Dryer (Dryer Repair)
by josiec 8/20/2013 12:38:26 PM(UTC)
GE electric dryer won't heat up (Dryer Repair)
by jrogers 7/4/2013 11:55:26 AM(UTC)
GE Electric Dryer suddenly got loud (Dryer Repair)
by Newbie2 12/15/2012 6:58:35 PM(UTC)
GE Electric Dryer - Won't Start (Dryer Repair)
by stockejj 10/31/2012 8:38:36 AM(UTC)
GE Electric dryer no start (Dryer Repair)
by TravisG 4/12/2011 1:30:52 PM(UTC)
GE electric dryer wont start (Dryer Repair)
by cojay 3/13/2011 6:38:17 PM(UTC)
trouble replacing belt GE Electric Dryer (Dryer Repair)
by lshelly40 2/6/2011 11:23:33 AM(UTC)
GE Electric dryer, no heat (Dryer Repair)
by khoshkkon 11/25/2010 10:38:07 AM(UTC)
Ge Electric Dryer Start Switch (Dryer Repair)
by lwpeters52@hotmail.com 10/16/2010 2:06:48 PM(UTC)
