khoshkkon
#1 Posted : Thursday, November 25, 2010 10:38:07 AM(UTC)
khoshkkon
Model# DWXR473ET2WW
The dryer spins but no heat. Shall we change the thermal fuse? And if we need to do it, where is this fuse? I can not locate it. Please HELP :) I am not at a stage to buy a new one :(
#2 Posted : Sunday, November 28, 2010 1:58:44 AM(UTC)
Here is the parts breakdown
Replacement parts for General Electric DWXR473ET2WW Electric dryer | AppliancePartsPros.com
GE likes to keep all tech info a secret but I would look in the control console to see if they have stoerd the wiring diagram in there.
First I would check that the unit is gettin the correct power.
Motor, timer etc. run on 120 volts but the heaters require the full 240 volts.
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Many GE's use 2 elements so try the different heat settings.
If some of them work then it could be one of the elements has burned out.
The thermal fuse is Item 507 in Section 3.
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I beleive richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal fuse blows.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
Here is a good site with dryer repair info
http://www.applianceaid.com/dryers.html
