Dak
#1 Posted : Wednesday, May 12, 2010 7:30:46 AM(UTC)
Dak
Hi, I am experiencing trouble with this microwave. The area where the touch pad is continues to turn on and off. Sometimes when you shut the door to hard and sometimes by it's self. It still works after a pull the plug and re-set it, but goes back to acting up. The light that shows the time has a slight flicking to it. Just appears to be acting up. Would like to know what parts are needed to correct it and get it working again. Thanks for your time with my problem. Dennis K.
#2 Posted : Wednesday, May 12, 2010 1:38:53 PM(UTC)
Originally Posted by: Dak Go to Quoted Post
...The area where the touch pad is continues to turn on and off. Sometimes when you shut the door to hard and sometimes by it's self. It still works after a pull the plug and re-set it, but goes back to acting up. The light that shows the time has a slight flicking to it...
Dennis,
If there is a problem with the display which goes on & off, the correction is to replace the control (PCB) board.
- The control board Part number: AP4064477
Dak
#3 Posted : Wednesday, May 12, 2010 2:13:44 PM(UTC)
Dak
Hi Gene, Thanks for getting back to me so fast. If you don't mind, I need to ask you another question regarding this problem. I would like to know on a scale from 1-10 on how hard is it to replace? I am pretty handy. Thanks again Dennis K.
#4 Posted : Thursday, May 13, 2010 7:42:24 PM(UTC)
Hi Dennis,
I would say probably 4 to 5.
Dak
#5 Posted : Friday, May 14, 2010 8:40:29 AM(UTC)
Dak
Hi Gene Thanks again for your help. I think I'll give it a try. Dennis
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
Replace the main control panel? (Microwave Repair)
by Guest 10/25/2021 7:11:40 AM(UTC)
line voltage in old Whirlpool control panel? (Dishwasher Repair)
by Paul_illinois 2/19/2014 7:40:06 AM(UTC)
Can I test a Control Panel? (Oven Repair (including Ranges and Cooktops))
by opeter 11/6/2013 9:27:43 AM(UTC)
Is it bad that there is debris under my control panel? (Dishwasher Repair)
by abahan 8/22/2013 2:18:18 PM(UTC)
I fixed one problem, but did I fry control panel? (Oven Repair (including Ranges and Cooktops))
by friendly_jacek 12/15/2012 7:04:22 PM(UTC)
Maytag Dishwasher quietseries 200 control panel? (Dishwasher Repair)
by Maytagwhat? 12/12/2012 6:52:42 PM(UTC)
Element or control panel? (Oven Repair (including Ranges and Cooktops))
by gettmac 1/23/2012 2:50:03 PM(UTC)
Control Panel? (Washer Repair)
by Sutherland 11/28/2011 11:47:24 AM(UTC)
Maytag won't fill. Valve or Control panel? (Dishwasher Repair)
by tdfaber 10/1/2011 1:21:37 PM(UTC)
How do I replace the electronic control panel? (Washer Repair)
by AWC 9/7/2011 9:12:30 AM(UTC)
Replace control panel? (Dishwasher Repair)
by merple 6/8/2011 10:41:51 AM(UTC)
Control board or control panel? (Oven Repair (including Ranges and Cooktops))
by Julie0012 5/19/2011 6:00:45 AM(UTC)
control panel? (Dryer Repair)
by guyfino 2/4/2011 7:35:28 AM(UTC)
Kitchenaid Dw: Need New Control Panel? (Dishwasher Repair)
by chipLAT8706 11/5/2010 12:31:07 PM(UTC)
