Our washer won't spin it will only spin when it is washing not on the spin cycle. I was wondering what part number to buy? And the error code is E47. Which I believe means a new door lock. If so how do I install?
The "E47" error code means "Board thinks the door PTC circuit is open in spin". Remove the door lock and check the resistance of the PTC. It suppose to be around 1500 Ohms. If the reading is correct, replace the control board. - The door lock Part number: AP4455026
