kathy ouellette
#1 Posted : Sunday, July 12, 2009 10:25:11 AM(UTC)
kathy ouellette
I have a Calupso washing machine that will not spin. It gets to the last 6 minutes of the cycle, and begins spinning. It makes an unpleasant noise then stops. This is after I have gotten the error code lp and the machine has been opened and the rinse spin cycle has been selected to finish the wash. Up to this point I have had no problems. Any thoughts?
sidfink43
#2 Posted : Monday, July 13, 2009 11:57:24 AM(UTC)
sidfink43
Hi Kathy
Well, you asked for thoughts, here are some.
These are really great machines, but are very difficult to work on. Also, the LP error code does not seem to be in the troubleshooting guide. Noises are also difficult to diagnose because the way we do that is to first listen and try to ascertain the area that is causing the noise, and we cannot do that in your case.
I am going to link you to the service manual for this machine, and suggest you try the troubleshooting and diagnostgic routine to see if you can come up with something. I am also going to suggest that you remove the pump and clear out any debris and check it to see if that is the source of your noise and problem.
Here is your manual
http://adcxns1.whirlpool...4632a4/$FILE/8178010.pdf
Good luck, sorry not to have been of greater help.
Machine won't spin - makes loud noise (Washer Repair)
by lpcon 7/18/2014 4:36:22 PM(UTC)
Washing machine won't spin (Washer Repair)
by Mjbruner1 10/3/2013 1:33:04 PM(UTC)
Washing Machine won't spin out water (Washer Repair)
by dlong55 9/29/2013 6:45:30 PM(UTC)
Washing machine won't spin or drain after rinse cycle (Washer Repair)
by brodyn 2/19/2013 7:45:13 PM(UTC)
frigidaire flse72gcs7 gallery laundry center washing machine won't spin (Washer Repair)
by hyperturtle 1/14/2013 8:18:44 PM(UTC)
by watertoy321 4/25/2012 11:29:09 AM(UTC)
by Monty Wyne 8/2/2011 11:13:08 AM(UTC)
Washing Machine won't spin (Washer Repair)
by golfer63 6/5/2011 9:03:36 AM(UTC)
Washing Machine won't spin only tries (Washer Repair)
by tferguson1970 5/23/2011 8:25:23 AM(UTC)
by neely732 5/11/2010 4:09:49 PM(UTC)
washer machine won't spin (Washer Repair)
by elbebe2525 1/6/2010 10:59:58 AM(UTC)
by telesa 11/2/2009 9:51:52 AM(UTC)
by stevecook 6/24/2009 2:09:23 PM(UTC)
hotpoint washing machine won't spin with clothes (Dishwasher Repair)
by Wayne Thomas 5/26/2009 8:03:37 AM(UTC)
washing machine won't spin the water out it (Washer Repair)
by jgosch 5/9/2009 10:58:46 AM(UTC)
