Good Morning!
My microwave is not heating anymore. It appears to work normally, it just won't heat up.
And no, I didn't put a fork or any metal in there.
Thanks!
This microwave made overseas and all technical information has been kept by Sears as a top secret. All parts are sold by Sears only as well.
you can do some testing.. 1. check 120 volt to primary 2. if ok check large cap and large diode 3. if ok replace magnetron.. (verify that you have 10 amp or so with clamp on amp meter to the magentron) 4 is 120 primary is missing look into control board area for loose connections. and such may need new control board
