SheriO
#1 Posted : 15 years ago
SheriO
Good Morning!
My microwave is not heating anymore. It appears to work normally, it just won't heat up.
And no, I didn't put a fork or any metal in there.
Thanks!
#2 Posted : 15 years ago
This microwave made overseas and all technical information has been kept by Sears as a top secret. All parts are sold by Sears only as well.
tvtech
#3 Posted : 15 years ago
tvtech
you can do some testing..
1. check 120 volt to primary
2. if ok check large cap and large diode
3. if ok replace magnetron.. (verify that you have 10 amp or so with clamp on amp meter to the magentron)
4 is 120 primary is missing look into control board area for loose connections. and such may need new control board
Hotpoint/GE/Kenmore microwave blowing fuses (Microwave Repair)
by mje2019 4 years ago
kenmore microwave (Microwave Repair)
by phi2cor 11 years ago
Kenmore microwave 85470 (Microwave Repair)
by Binger 12 years ago
Kenmore Microwave hood combination (Microwave Repair)
by curtisd 13 years ago
Kenmore Microwave (Microwave Repair)
by jlezette 13 years ago
kenmore microwave repair (Microwave Repair)
by ploou 13 years ago
kenmore microwave, runs when plugged in, wont shut off (Microwave Repair)
by ice3x 14 years ago
kenmore microwave has f2 error code (Washer Repair)
by bobval 14 years ago
Kenmore microwave hood combo, no heat (Microwave Repair)
by billbr 14 years ago
Replace Kenmore Microwave Door Latch (Microwave Repair)
by kwells 15 years ago
'F3' display on the Kenmore microwave screen (Microwave Repair)
by jennifer555 15 years ago
Kenmore Microwave no heat (Microwave Repair)
by desgross 15 years ago
Kenmore microwave does not heat (Microwave Repair)
by srikki9 16 years ago
Kenmore Microwave -No Heat, No Turntable -Related? (Microwave Repair)
by airheads 16 years ago
Kenmore microwave no heat (Microwave Repair)
by nhdad17 16 years ago
