orion359
#1 Posted : Monday, March 29, 2010 3:56:34 PM(UTC)
orion359
My kenmore 60 series washer stopped spinning but would still agitate and drain. It soon stopped agitating as well. The motor coupling was indeed broken so I replaced it and now it vibrates and sounds like it wants to spin but still does not. I thought I installed the coupling wrong and took it apart and tried again but still to no avail. Is there something I missed or is there more damage done? thanks
sidfink43
#2 Posted : Wednesday, March 31, 2010 3:42:08 PM(UTC)
sidfink43
If it drains then the motor is turning ok, and I suspect a problem in your transmission. The machine is in neutral when it drains, so it sounds like your problem occurs when the transmission tries to enage.
