AppliancePartsPros.com
Appliance Repair Help
Washer Repair
kenmore 60 series not spinning after motor coupling replacement
My kenmore 60 series washer stopped spinning but would still agitate and drain. It soon stopped agitating as well. The motor coupling was indeed broken so I replaced it and now it vibrates and sounds like it wants to spin but still does not. I thought I installed the coupling wrong and took it apart and tried again but still to no avail. Is there something I missed or is there more damage done? thanks
If it drains then the motor is turning ok, and I suspect a problem in your transmission. The machine is in neutral when it drains, so it sounds like your problem occurs when the transmission tries to enage.
Washer Repair
