I replaced the motor coupling of my washer and seem to work fine for a while. now I noticed that the center part inside the drum that does the agitating? Is not turning, what do you think is causing this problem?
Hi nflordeliza
If you can post the complete model number of your washer I might be able to help you with your problem. The model number is located under the lid.
Originally Posted by: Gene  Hi nflordeliza If you can post the complete model number of your washer I might be able to help you with your problem. The model number is located under the lid. Gene. I have a similar problem with an agitator on my Whirlpool washer that will not turn under its own power. I have ordered a cam and dogs kit and am looking for advice on how to install the kit. My model number is LSQ9564JT0. Tom
