vze1kobm
#1 Posted : Tuesday, May 13, 2008 7:14:33 AM(UTC)
vze1kobm
My Friend has a old Kenmore washer 80 Series Ultra Fabric Care and it only agitates but won't spin out the water.What could the problem be.I believe this unit has no belt and I need some help in order to help her fix it.:confused:
SublimeMasterJW
#2 Posted : Tuesday, May 13, 2008 9:41:56 AM(UTC)
SublimeMasterJW
The pump mounts on the motor. The motor pumps out the water. It won't pump or spin if the lid is open. Check the lid switch. Here is a picture of a broken lid switchSpeed switch for kenmore.jpg
SublimeMasterJW attached the following image(s):
SublimeMasterJW
#3 Posted : Tuesday, May 13, 2008 9:46:39 AM(UTC)
SublimeMasterJW
Unplug the lid switch quick plug as pictured
Check the 2 outer connectors for continuity. With the lid shut the switch should have continuity. If it is open it is bad. To access the switch simply pop those brass S-clips and tip the outer case forward.
Washer Agitates but Won't Spin, Drum Dropped (Washer Repair)
by dagwinn 8/17/2017 4:47:57 PM(UTC)
Admiral aav7000aww agitates but won't spin (Washer Repair)
by chenzzo 12/29/2016 9:06:46 AM(UTC)
Agitates but won't spin (Washer Repair)
by WTAIII 1/21/2016 6:06:45 PM(UTC)
whirlpool washer agitates but won't spin (Washer Repair)
by vinzant15 2/7/2015 12:16:09 AM(UTC)
Roper washing machine agitates but won't spin out. (Washer Repair)
by Ktlyn129 7/20/2014 4:13:09 PM(UTC)
by nmckaskle 9/28/2012 5:34:58 PM(UTC)
GE washer agitates but won't spin (Washer Repair)
by nicolle_m 5/17/2012 5:57:01 PM(UTC)
wirlpool topload agitates but won't spin or pump motor hums (Washer Repair)
by curly33333 5/16/2012 6:51:35 AM(UTC)
GE Washer agitates but won't spin (Washer Repair)
by splitune 11/25/2011 1:26:23 PM(UTC)
top load fills&agitates but won't spin/drain (Washer Repair)
by mellnyy 8/28/2010 8:16:15 PM(UTC)
washer fills and agitates but won't spin or drain (Washer Repair)
by Jim Bags 7/6/2009 4:37:15 PM(UTC)
by Bab 2/17/2009 7:49:43 AM(UTC)
Kitchen Aid Washer Agitates But Won't Spin (Washer Repair)
by leroypg 10/16/2007 8:31:06 AM(UTC)
washer agitates but won't spin` (Washer Repair)
by mls6089 10/12/2007 7:34:53 AM(UTC)
