jwysocky
#1 Posted : Saturday, February 20, 2010 10:28:06 AM(UTC)
jwysocky
My GE electric dryer timer won't advance in the automatic modes.(DRXR473EWOWW). I replaced the timer in a recent purchase from APP.com:(. The dryer dries in all modes, but the timer only advance in the timed drying mode which is OK, so it is usable. I see in the parts list a resistor and thermostats, but have no idea where to go from here. I've cleaned all the duct work front and back.
John
jwysocky
#2 Posted : Tuesday, February 23, 2010 5:40:31 AM(UTC)
jwysocky
Come on guys, someone must have an idea of whats wrong.
John:)
#3 Posted : Tuesday, February 23, 2010 6:14:19 AM(UTC)
Cannot find any info using given model number.
When you replaced the timer did you find the wiring diagram in the control console?
How this often works is that in Auto modes the timer motor gets power through the heating coil when the heating coil is turned off.
The resistor you mentioned may be there to drop the heater voltage from 240 to 120 for the timer motor.
Remove it and check it for continuity, usually 5,000 to 10,000 ohms.
Also check that the temp settings actually change the temperatures.
You may have a grounded element re: the element never turns off.
jwysocky
#4 Posted : Tuesday, February 23, 2010 6:25:45 AM(UTC)
jwysocky
DRXR473EWOWW This number is listed above.
I have the wiring diagram and will check the resister. If you put the auto near the end of the cycle it will work and the heat will not be on.
Thank you John
#5 Posted : Tuesday, February 23, 2010 7:19:48 AM(UTC)
Yes I saw the model number just cannot find any info.
Does sound like it may be a grounded element, wish I had the wiring diagram.
At the end of an Auto cycle the unit goes into cool down to prevent wrinkling and shuts the heater off using a set of timer contacts.
Note: Some GE's use dual elements so if one of them burns out you will stall have heat but no timer advance.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case.
jwysocky
#6 Posted : Tuesday, February 23, 2010 8:52:21 AM(UTC)
jwysocky
If you have a fax no. I can fax wiring diagram to you if that will help. the wiring diagram does show a inner and outer heating coil. My question is do I remove a side panel to get to the heating element?
#7 Posted : Tuesday, February 23, 2010 1:20:15 PM(UTC)
Often you can get at them from the top depending on the dryer.
Perhaps the following will help
http://www.applianceaid.com/ge-dryers.html
jwysocky
#8 Posted : Thursday, February 25, 2010 1:54:49 PM(UTC)
jwysocky
If it happens to be a heating element, I'm not going to put another $200 into and old washer. I already made a mistake thinking it was the timer $80 dollar latter I'm no further ahead and a Repairman will probable be in the $400 range.. I just keep using it till the other heating element quits. thanks for trying
John
