Washer spin cycle not working, only works if I manually get tub spinning first. From looking at other posts it sounds like a bad clutch. Going to order clutch kit. Do I have to remove the spanner nut to get the shaft down through the bottom of tub to access the clutch? and if so do I need a special tool?
