sailman
#1 Posted : Sunday, April 27, 2008 7:07:59 AM(UTC)
sailman
IN normal wash mode the cycle stops; does not drain but the timer proceeds through the spin cycle without draining and no spin. I can advance the spin to the Gentle spin and it drains and spins but not as long as the Normal mode. Is this a timer problem ? Or some other part not enganging the spin and drain ? Before I spend a bunch on a new timer.
misterfixall
#2 Posted : Sunday, April 27, 2008 4:56:29 PM(UTC)
misterfixall
it may be a motor problem .does it only function in gentle but not normal or permanent press? if this is a2 speed motor ,the regular speed may be not working
sailman
#3 Posted : Monday, April 28, 2008 6:15:42 AM(UTC)
sailman
The motor works in Normal wash/fill/agitate cycle. The timer advances through drain and spin but the washer does not actually drain or spin in Normal. I think the Spin cycle only works in Gentle. Motor works in all wash cycles.
misterfixall
#4 Posted : Monday, April 28, 2008 6:32:53 AM(UTC)
misterfixall
it could be motor
sailman
#5 Posted : Monday, April 28, 2008 6:43:21 AM(UTC)
sailman
thanks but I am confused . do you mean the main motor or the timer motor ? could it be a gear not engaging or the timer is worn and not connecting at certain spots ? the motor works, that's pretty clear. Thanks
misterfixall
#6 Posted : Monday, April 28, 2008 7:43:51 AM(UTC)
misterfixall
the main motor ,the spin portion of the motor in normal +pemanent press does no engage only in delicate this is a 2 speed motor
