I Have Got 2 Tenants That Use There Oven To Heat There House. Both Have Burned Out The Bake Element. I Order A New Element And Replaced Them Both, But The Oven Still Wont Work On Either One Of Them. Ever Thing Else Works. Thanks For Any Heilp. Tim Ps- Boiler Doesnt Work Either
Pull the range out of the wall, remove the rear cover and check all wires. If there is nothing wrong, replace the EOC (aka a clock/timer). It has to be replaced together with the overlay because it's glued on. - The clock/timer Part number: AP3775600
