hooterz
#1 Posted : Sunday, January 10, 2010 9:55:12 PM(UTC)
hooterz
I have a Kenmore dryer that squeels when you start the dryer. I removed the drum to to get to the motor and when I spin it over by hand it make the squeek noise, so I would assume it's the bearings on the motor going south. My question is how do I get the blower wheel off. I know it threads on but which way to I turn it to get it off and how is the best method of removing. Thanks for any help
#2 Posted : Monday, January 11, 2010 2:25:52 AM(UTC)
This should help
http://www.applianceaid.com/whirlpool-dryers.html
See #13.
Often they do not come off without destroying the blower wheel.
hooterz
#3 Posted : Monday, January 11, 2010 5:19:09 AM(UTC)
hooterz
So can I put a wrench on the belt end and 1/2 drive ratchet w/ extention on the pulley side to remove blower wheel? Also is this left hand thread?
#4 Posted : Monday, January 11, 2010 5:25:35 AM(UTC)
Yes to both
ReCo
#5 Posted : Friday, January 22, 2010 4:11:15 PM(UTC)
ReCo
The air impleller on my new motor is right hand threads. lock the motor with a 7/8 socket on the pulley end in a socket. inset 1/2 extension in the front of the impleller and turn clockwise. that is what my instructions said to do. the threads do match this form, but my plastic caved in!!! might want to put some wd40 on for while first. just hope your luck is better than mine reco
hooterz
#6 Posted : Friday, January 22, 2010 6:38:53 PM(UTC)
hooterz
I had to destroyed the blower wheel to get it off. Replace the motor and blower wheel and now it runs like a champ. Thanks for all the help.:D
#7 Posted : Wednesday, January 27, 2010 1:35:05 AM(UTC)
Glad to hear you are up and running.
Seems that more often then not the blower wheel has to be destroyed or perhaps on this forum we only see the blower wheel problems when it cannot come off.
