I had both ovens going the other day. After ending the bake cycles, the panel just went dead! Black! If I open the oven doors, the lights turn on. If I push the start button I get a dit daaaa dit dit dit sound. But other than that, no action. I turned off the breaker box to try to "reboot" it, but no go. Nothing. I hope there is something easy to fix that I am overlooking. I've never had problems with my ovens before! Thanks in advance for any help.
THIS FORUM IS DEAD!!!!!!! |
My oven has the very same problem. I was told the control panel needs to be replaced, but that part is not available and on back order! I'm thinking that is a widespread problem. My oven is about 7 years old.
Originally Posted by: ms.nita ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My oven has the very same problem. I was told the control panel needs to be replaced, but that part is not available and on back order! I'm thinking that is a widespread problem. My oven is about 7 years old. Just found out from whirlpool today, they no longer make the part I need! Now I need a new oven....it won't be a whirlpool! :mad:
I have the Whirlpool Double Oven and the control panel went out after 4 or 5 years. It has now gone out again. And it's not cheap!! Can't believe it. Must a design flaw in this model cause others have reported the same thing.
Rafasan
Are you sure it is the control board or has it blown the thermal fuse that kills power to the board? |
yes, I checked the fuse and it's fine.
Mine did this before. Left the power off for a while and when power came back on it was fine. It has been 2 years since then and it just went out again. Same issues, light works, beeps when you touch buttons. I will try leaving power off for an hour like before.
I have had the same problem with my oven shutting down, then coming back to life for no reason. I just noticed this week that it has been back up for the past week and the only thing I can think of that has changed is the humidity has been high for the past week. It is still lit up as I write this and this has not happened for longer than a day or two for the past year. I will be checking on this for a while to see if it is the humidity that is affecting this, and if so, will be doing something to make the humidity high around the oven.
Originally Posted by: dozija ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I had both ovens going the other day. After ending the bake cycles, the panel just went dead! Black! If I open the oven doors, the lights turn on. If I push the start button I get a dit daaaa dit dit dit sound. But other than that, no action. I turned off the breaker box to try to "reboot" it, but no go. Nothing. I hope there is something easy to fix that I am overlooking. I've never had problems with my ovens before! Thanks in advance for any help. WE were cooking same thing happened as you, we get no oven light, no codes or sound? :confused:
